Alt 19.01.2012, 15:57
Divefreak
Zitat von knightwhosaisnee Beitrag anzeigen
Jaaaaaaaaa....vermutlich ist es das
Ich merk schon du weißt nicht worauf ich anspiele....
http://www.personalwatercraft.com/fe...ions-1091.html
OTS systems began to appear across all major PWC manufacturer’s lines around 2003.
The motivation behind their appearance can be traced to calls from the Coast Guard and National Transportation Safety Board for a solution to a PWC’s lack of directional control once thrust was removed. Those calls were spurred by a 1998 NTSB study that found most PWC fatalities were not the result of drowning, but instead blunt force trauma — the type of accident that results from a collision with another boater or fixed object. As PWC essentially lost most directional control once a driver released the throttle, manufacturers agreed to work on a solution that would return some minimal level of control to the driver and help avoid a collision.
