Ich hab dieses hier mal zur Info aus dem rib.net kopiert.
The main feature of the assault seems to be that the tubes are mounted lower on the hull than most other ribs, which means that the boat is easier to climb into from the water but that the tubes drag in the water at speed and give a bumpy ride in rough water.
Even with a 90 and the engine mounted high I'm only getting 40 knots on GPS.
However even with a forty four stroke the boat planes ok however many people are in it as long as you spread the weight around.
Hull shape is a fairly deep v ,I think the only drawback for use in rough water is the tube height.
Which is why the destroyer and ocean pro have the tubes mounted much higher up.
Vielleicht hilft es ja bei der Entscheidung.
Gruß Anton
